Old 01-04-2011, 22:58
ollymk4escort ollymk4escort is offline
ollymk4escort is an unknown quantity at this point
Default Help me determin this outlet,ca18et
On the back of the head on the inlet side I have an inch hole with a thread in it
What goes in it.?
Cheers
Old 02-04-2011, 18:17
The head? Or the top of the inlet manifold?
Cause I'm sure theres people on here thinking the same as I am!
Old 02-04-2011, 20:04
At the back of the head there is a sort of plate bolted to the head and there is like an inch threaded hole like a water outlet? I just need to know if I can block it up
Old 02-04-2011, 21:18
isn't it summet to do with water cooling, i'am sure some countries run water down the back of the plenum as some have a recess on the plenum that can be plated over, probably me got it wrong,
silviagod would know.
Old 02-04-2011, 21:29
It's not on the plenum it's on like a cover on the back of the head with a threaded hole. It's on the spare engine I have also
Old 02-04-2011, 21:49
yeah i know what you mean ,its like a small hose fitting on the back of the head,i was just saying that some of the plenums have a water matrix cast into them,
