Old 30-04-2012, 21:48
tim murphy's Avatar
Default what did you do on your silvia today ?
got my fuel tank back and started anti rust paint on it two coats then rust primer two coats and two coats of silver that should do it .and then put my susp leg together looking ok cheers.
Old 01-05-2012, 13:01
Hi mate, how did your tank turn out after blasting and how much did it cost you?
Old 01-05-2012, 21:38
tim murphy's Avatar
hi dave my tank turned out good no repair needed just the over flow pipe on top of tank to sort out sand blasting cost my 20 quids off a mate silvia coming on good working on her each night and still off the fags too . cheers
