Old 02-01-2013, 22:36
tss240zg tss240zg is offline
tss240zg is an unknown quantity at this point
Default DiY coilover conversion
Thinking of doing a rally design coilover conversion
I was told by s13eater to get a 2 and a quater threaded tube....grind the spring cup off the std strut and weld it up. But can this be done at the back as springs and shocks are separate.... Spring is free so it is not a strut... So what should i do.
Any help appriciated
Thanks
Tss240zg
Old 03-01-2013, 10:57
Thanks
Tss240zg
i've also done a rear conversion to mate, there should be pics on my build thread.
Old 03-01-2013, 11:00
Old 03-01-2013, 12:32
Found the thread
Did you have to reinforce the strut tower as i heard it can warp the sheet metal?
Old 03-01-2013, 13:17
Found the thread
this set up just makes the rear end ajustable in height plus you can choose your own spring rates.this uses the original spring and shocker position, so no reinforcing needed.
Old 03-01-2013, 13:31
In what cases will you have to reinforce the strut towers....
Noticed in your coilover thread a lot of the pics not showing... are they still on your photobucket page
Thanks
Tss240zg
Old 03-01-2013, 19:29
Thanks
Tss240zg
no you won't have to reinforce the towers with that conversion, i'll check my photobucket mate.
Old 03-01-2013, 20:23
Cheers
Old 03-01-2013, 20:55
Cheers
sorry mate, they look like they have been deleted, when was you thinking of doing the conversion ?
Old 03-01-2013, 22:05
probably in february....
