Old 25-02-2013, 11:15
thenomisf thenomisf is offline
thenomisf is an unknown quantity at this point
Default Gearbox Dirt Guard / Sandwich Plate
Hi All,
I am converting my auto s12 to a manual, as anyone who has been in the Wanted section probably knows all to well.
I am aware there is a thin metal plate that goes between the gearbox and the engine to stop crud getting into the bellhousing. I also know you can run without it, but it screws up bearings/flywheels.
My question is, seeing as the bolt patterns are the same - would the "crud guard" plate from an S13 / CA18DET fit on a 12 / CA18ET ?
Thanks
Old 25-02-2013, 12:38
im 99% sure it will as the bellhousing patterns the same and they look pretty mcuh identical.
Old 26-02-2013, 10:36
Cheers, I will see if I can find one!
Also does anyone know the dimensions / type / where to get a spigot bearing for the manual box/crank ?
