Old 07-05-2014, 15:14
van_denton van_denton is offline
van_denton is an unknown quantity at this point
Default CA18DET Wiring LOL lol LOL
Hi,
Ive nearly finished wiring this dood in! but have a few questions.
1, should this little IACV plug be wired into the loom? if so where?
any help of any kind would be appreciated.
cheers
Old 07-05-2014, 16:56
Default sorted
found it
F.I.C.D Solenoid valve, only used for A/C. Increases idle speed when AC is on.
Old 13-05-2014, 11:20
well ive been reading everything I can on this conversion and I think ive confused myself!!? so I need to check.
This is what I have?
If that is correct I have a few kinda dumb ass basic questions?
1) Where is the best place to get 12v constant on? Do I take it straight from the battery and add a switch so I can turn all the 12v constants off? or should I connect into the s12 loom some where?
2) Kinda same question as above but with the ign on source? off of the ignition barrel? which wire?
cheers,
Paul
