Old 23-10-2005, 21:57
s12Rob's Avatar
s12Rob s12Rob is offline
Default s12 volvo ic setup
hi all am in need of one of these, so far i have the 740ic, the 740 non turbo rad and ounting brackets with expansion tank. anything i have forgton.
now all i need to know is how to plumb it in and what to use
Old 24-10-2005, 11:33
bigtim's Avatar
bigtim bigtim is offline
A shit load of pipes and clips
Old 24-10-2005, 17:28
A suitable electric fan and switching may be needed as you will probably have to ditch the mechanical unit to create some space.
Old 24-10-2005, 18:05
s12Rob's Avatar
thanks for ya help, anymore detailed instructions and pics would be nice
Old 25-10-2005, 13:21
I've got a big intercooler of unknown origin front mounted on mine, mounted where the radiator was with the radiator on a custom made mount behind. It's still awaiting pipe work but I've still got the mechanical fan but without the cowl so there is space if you want to keep the original radiator.
Old 25-10-2005, 15:00
I just used some of the original volvo piping and some samco. You can use scrapyard rubber if you can find it.
Old 25-10-2005, 15:42
s12Rob's Avatar
is that the volvo rad u have there too??
Old 25-10-2005, 15:53
This is a photo of the radiator with the intercoler in front, it's actually larger than the radiator and as I said it just needs some pipe work, I haven't made up my mind weather to go to the scrappies or make some up myself yet or rather my pocket hasn't.
Old 25-10-2005, 15:57
Id be interested to see pics or your setup as it sounds simillar to mine except i am using electric twin 12" kenlo fans and there like huricanes
Pics would also help others to get ideas
Old 25-10-2005, 16:05
Yeah volvo turbo rad
