Old 26-04-2006, 17:19
Default Standard Boost
What's the standard boost for a S12 with the standard T2?
Old 26-04-2006, 17:51
6-7 psi mate
Old 27-04-2006, 08:14
Thanks so 96bhp ( 129bhp flywheel ) is not bad for a 80000 mile engine on standard boost.
So what would the safest psi to take it to without any risk of damaging the engine with and without I/C and what grade plugs?
Old 27-04-2006, 08:31
about 10psi and bcpr-7es plugs.
Old 27-04-2006, 09:15
i bet if you set up you tappets / timing and plug gaps spot on the car will be back to 135bhp. on standard boost you can up the timing from 15dbtc to 17.5dbtc to get a few more bhp`s
Old 27-04-2006, 19:22
Cheers for the info, give me something to think about but before I start tinkering I've got to solve the missfire on no.1 on tick over before playing with anything else.
Old 27-04-2006, 20:19
test your plug leads with a multi meter. from memory if it reads more that 18 ohm its naffed
Old 27-04-2006, 21:28
Thanks but I don't think it's the leads as I replaced them a couple of months ago along with the coil.
Old 27-04-2006, 21:37
I used those orange hotwire leads on my 8v engine and they deteriorated and were nackered in under 2 months. So i bought some Magnacore leads and i did notice the difference in engine performance.
As Shaun says and set the plug gaps to .9
Thats a very healthy bhp figure you have there considering. Exhaust and air filter modifications will help just as much as a boost increase
Old 27-04-2006, 22:56
i had a set of orange hot wires too once, and everytime it rained without fail it would only run on 2 or 3 cylinders once spent a whole week on half the engine firing, sounded like an old derv......
i got some genuine nissan leads, that was 6 years ago, and they have never misfired yet. worth paying the extra money
