Old 01-07-2016, 09:46
nedge2k nedge2k is offline
Administrator
Default Replacing door weather strips
Taken from our Facebook group, member David Laird has this great tip for replacing the weather stripping at the top of the doors...
For all you that have rusting degraded or missing door weather strips I've found the answer.
As you know the seals are like hens teeth for ok condition ones and even harder to get good ones.
I've managed to (with the aid of a hacksaw and a drill) to get a pair that fit perfectly 😉
Also managed to stay faithful to the nissan family for the parts 😂
R33 skyline gtst or gtr as both are the same, the drivers side skyline one goes on the passenger of the silvia, you cut about 6cm off them and take the plastics from the other end and fit to the open end then drill a pilot hole for the screw to go through, you need the skyline clips and the silvia door frame has small brackets insane that the skyline clips line up with so that they don't pop out when operating the windows
Original post: https://www.facebook.com/groups/1787...4876455376618/
1985 Mk1 Black Auto
1989 Mk2 Red Auto
1988 Mk2 Blue Manual
1988 Mk2 Blue Manual (Donor)
