Old 29-04-2006, 10:14
wimdepim wimdepim is offline
S12oc Newbie
wimdepim is an unknown quantity at this point
Default need some help
hey everybody
i have a problem
i want to buy a better turbo
but down here(belgium) is a problem very expensive items
so if someone get tell me what i need to change turbo fuel exhaust ? i would like about 200-220 bhp in the car
and if one of you makes the deals and send it to me i would really be glad
i am running at the moment with a stock turbo with more boost, closed the return fuel line a bit for more fuel pressure and installed a small intercooler from a mercedes vito cdi and got about 175bhp at the moment
i hopesomeone can help me
thanks mates
Old 29-04-2006, 11:04
For 200-220bhp at the flywheel your easiest option would be to fit a t25 (standard spec on the s13). The simpest conversion includes using the same turbo gasket,the s13 downpipe and the s13 oil return line. You will need the s13 3 bolt flange that bolts onto the t25 compressor outlet aswell and then adapt it to the shape of your pipework directions with a hacksaw and maybe a aluminium welder.
Running at 15psi your should see around 220bhp aslong as you have a healthy engine with decent filter and exhaust system
Old 29-04-2006, 20:23
after having my fuel pressure reg fook up and give me near full pressure 60 ish PSI) at the injectors, is blocking off the fuel return a good idea???? i found it has massive over fuel.
Old 29-04-2006, 21:03
S12oc Newbie
just got it running again it was rolling on 3 piston and had to change airflowmeter sparkplug wires 1 sparkplug and clean it i'd just replaced sparkplugs last week
and now i was bussy i installed an intercooler as well (broken last race)
i replaced airfilter(big race filter) 2 weeks age could it be that it run bad and needs adjustments?
i saw a adjustement crew on the airflowmeter and don't now what it does!!
just got an offer for a t25 of a 300zx 88-89 version
lots of work ?
Old 03-05-2006, 17:39
S12oc Newbie
ok found a turbo a t25 from a rover 220 turbo with 65tkm(40tmiles)
for 250euro (235$)
now i just need to now if i have to change exhaust (bigger or not) and fuel system (just close return fuel line or changing other parts)
Old 03-05-2006, 19:03
can you not just find a s13 t25 and downpipe as pukka surgested surely thats the easiest route and then make yourself up a 2 1/2" exhaust with performance silencer if your going for 200+bhp,personally i would unblock the fuel return
Old 04-05-2006, 18:26
S12oc Newbie
down here cars with turbo's don't drive very mutch
the taxes are by kw here and the people here like to drive a lot with diesel
so it's buying whatever you find!! or new
unblock the fuel return?? does he get enough fuel on stock pressure?
Old 04-05-2006, 20:33
i have 2 1/2" exhaust,powerfilter,bigger throttlebody,dumpvalve,t25 turbo and large intercooler at 14-15psi on the standard fuel pressure
Old 08-05-2006, 21:55
S12oc Newbie
the 2 2/1" exhaust is it availleble or home made ?
with throttlebody you mean the air-intake after the turbo on topo of the engine right?this part http://www.club-s12.org/forum/showthread.php?t=13164
i still need to learn the technicale name of some parts
Old 08-05-2006, 22:13
exhaust you will have to make yourself or get made,yes the picture you show is of the throttlebody which wont add much but its better than nothing,i have a z31 turbo one on mine but the ka24 one is bigger still,dont forget to port your inlet manifold where the throttlebody bolts on if you fit one otherwise its a waste of time
