Old 28-05-2006, 15:24
Dan Dan is offline
Question newbie bolt question
So i had the chance to work on the car this weekend and was planning to replace the headlight. Unfortunatley though, when i was taking off the bolts that hold on the headlight cover (after removing the black plastic surround) the heads of two of them twisted off! So now i've got two bolt shafts stuck in the headlight, flush with the edge on both sides.
So, how do i remove these then? Or should i cut my losses and buy a new one?
Thanks very much
- Dan
Old 28-05-2006, 15:31
if you have no luck let me know as i have about 4 sets of lights.
Old 28-05-2006, 15:47
you might be able to drill them out and retap the threads
Old 28-05-2006, 16:03
Dan Dan is offline
how much for your best passenger side one mate?
how do you go about retapping threads? thanks for the reply
Old 28-05-2006, 18:39
bigtim's Avatar
bigtim bigtim is offline
Can you not tap the shaft round with a small dot punch after given it a blast with wd40
Old 28-05-2006, 19:52
best to drill and tap them as If you fit another, then You will have to get them Re-aligned at an MOT garage for the MOT like I did!!!
Old 30-05-2006, 16:35
Dan Dan is offline
have to replace it anyway, motor's gone in the original.
thnaks for the suggestions guys!
Old 28-05-2006, 21:45
you will need to drill a hole directly in the centre of the snapped off bolt (with a drill a bit smaller than the tap)then use the appropiate metric tap to cut a thread
