Old 29-05-2006, 23:24
akira2_03's Avatar
akira2_03 akira2_03 is offline
akira2_03 is an unknown quantity at this point
Default Project: custom headlights
well i figured since im re-doing my s12 i might as well change the headlights to try make it unique. so i am throwing in a pair of 1991 300zx headlights
and here are some pics of the project itself. it was pretty beaten up when i got it
more pics up soon since i just did quite a bit of work yesterday, new side fenders hood bumpers etc.
1987 s12 => Under Construction
1986 s12 55k mint (ca18et)
Old 29-05-2006, 23:48
akira2_03's Avatar
well here are some pics of tail lights. not done yet but soon, curtousy of s13eater (Shaun) thanks for the idea and help mate.
Old 30-05-2006, 00:01
good work mate, keepme updated, and on those front ones as well
Old 30-05-2006, 00:36
akira2_03's Avatar
yeah those front ones are gonna be quite the challenge, and i have to remold a hood so it will fit, but i think it will turn out great!
well here is some pics of what i've done so for...
the side mirror got wrecked from my buddy. i was teaching him how to drive stick and he tried backing up and side swipped the fence lol.
and for this last one the wiper blades are always set pretty high, so how do i set them lower so they are at the bottom of the windshield???? and the back one doesnt work, anybody ever change one before? is it hard?
Old 30-05-2006, 02:42
The front wipers are on a small toothed spline for which you have to remove the wipers and simply move them to what posistion you want.
As for the back it could be a number of things including the wiring to the motor or the motor itself, swapping the motor is not a hard job atall
Old 30-05-2006, 04:15
akira2_03's Avatar
well the front wipers are hard because there are the rods attached underneath and i dont know where to disconnect it. and the back one i ne ver tried or seen what it looks like under the cover but doesnt it have the rods there too?
Old 30-05-2006, 08:20
you dont have to mess with the rods underneath,at the base of the wiper arm itself there is a single nut which probably has a press on cover over it,take the nut off then pull the wiper arm off the spline and readjust where you like,same on the back
Old 30-05-2006, 08:32
akira2_03's Avatar
oh i see. thanks for the info
Old 30-05-2006, 09:48
Back Seat Chatter!
the wiper arms may be stuck on there really tight. Don't be afraid to use lots of force and wiggling to get them off.
Old 30-05-2006, 10:13
its a 14mm spanner you will need, just put some pressure on the bottom of the wiper arm with your thumb, so when its undone it keeps the pressure even on the spline, then lift with the other hand, this will stop you trying to lever it off and break things
