Old 13-06-2006, 01:00
eeep eeep is offline
eeep is on a distinguished road
Default Beginning to modify - advice?
Hi all.
I'm looking at buying some bits and pieces to start modifying my MK2 at some point, and these were the sorts of things I was looking at, any advice, feedback or suggestions? Price is a major factor at the minute, so I'm looking at picking things up to fit them at a later date.
Induction kit
or replacement filter?
Boost gauge and controller
I understand that new spark plugs and some adjustments to timing would also be needed? I'm pretty much a noob at cars, and this is what I've gathered from reading various threads, including this guide.
Cheers, Mike.
Old 13-06-2006, 08:58
hi,personally as a starting point the first things i would do to help with the breathing of the engine would be to fit a induction kit(not the ones you have to oil and not a replacement filter either)and a large bore exhaust system,i would fit these before anything else
Old 13-06-2006, 23:57
Cheers for the reply; I'm waiting for a guy to get back to me about a possible second hand SS exhaust.
On a different note, would a brace like this fit an S12?
Old 14-06-2006, 06:33
Back Seat Chatter!
you'll need an S13 one that's adjustable (like a discontinued cusco adjustable S13 front bar)
The reason being that the angle of the strut tower tops differs between the S12 and S13.
As for no oil charged filters...good rule of thumb. I use an oiled Ractive filter and dont' really have any problems. But he's right. You should use something like the HKS mushroom filter that's dry.
10psi on the stock engine and turbo isn't that big of a difference until you start doing some more supporting mods....like an intercooler, larger exhaust system and a larger turbo(which really isn't a SUPPORTING mod but it's one to liook into heh)
Old 14-06-2006, 21:51
so am i right in thinking this strut brace would fit, its supposed to be a cusco item
Old 15-06-2006, 13:31
we cant read your inbox dude!
Old 15-06-2006, 16:21
i see
anyway this one.....
Old 15-06-2006, 16:28
I tried to fit one and its about 3" too wide.
Old 15-06-2006, 16:39
i thought as much
Old 18-06-2006, 12:27
toytoy's Avatar
toytoy toytoy is offline
toytoy is an unknown quantity at this point
the S13 strut brace are 65mm too long ...
