Old 22-06-2006, 08:38
turbozx turbozx is offline
turbozx is an unknown quantity at this point
Default CA18ET crank in a CA18DET
i know that there are a different number of bolts holding the fly wheel so if i swapped the flywheel as well could it be done, as i have a DET with big end failure and scored crank and a good ET crank, could be a cheap repair?
Old 22-06-2006, 22:24
It would probably cost under 100 to have your damaged crank reground.That is at a guess. Have an ask around
Old 25-06-2006, 10:20
more like £70
Old 25-06-2006, 12:43
Zman Zman is offline
S12oc Newbie
Zman is on a distinguished road
If you where to change the crank the front cambelt sprocket would need to be modified. You would also need to use the ET oil pump. The reason is that the ET crank is smaler in diameter.
