Old 02-08-2006, 21:23
Dan Dan is offline
Default headlight issues..
hey guys,
i've just got a replacement headlight from s13eater... but im having trouble getting it to work. i think its the down retract relay, but here's whats happening:
when i manually retract the lights, then click the pop-up switch, both go up and then one (the new one) goes back down immediatley.
if i turn off the switch, nothing moves (the old one stays up)
if i turn it back on, again nothing.. etc..
any ideas?
also, how do you test relays and where can you buy them if needed?
Old 02-08-2006, 21:42
bigtim's Avatar
bigtim bigtim is offline
scrapyard for relays,take the ones you need probaly all 6(some will be same pins and colour) then say you want one off a nissan and put a load in your pocket and buy one,or say you want a wing off of sumat and get the relays that way.
