Old 10-08-2006, 09:36
s12Rob's Avatar
s12Rob s12Rob is offline
Default which would be better, t2 hybrid or t3?
any ideas
Old 10-08-2006, 10:19
You need to decide your aims, ie BHP and intended boost level.
I've got a T3, and if I had to chose again I would go for a GT28R or GT28RS
Old 10-08-2006, 13:55
Jeff Jeff is offline
Jeff is an unknown quantity at this point
Most T3's (there are various turbos out there referred to as T3) will be more laggy than a T2H but it will have potential for producing more power. A GT28R would be a good compromise on a tuned CA18ET I reckon
The T3 has a different manifold flange too and so will require modifications to the S12 manifold. On the plus side there are probably more turbo's out there using the T3 flange, as per the Ford Cosworth (Sierra/Saphire and Escort) and they can therefore often be a tad cheaper.
Old 20-09-2006, 23:25
Chuck an s13 t25 on there for peanuts if you dont intend on spending the £ to go over 220bhp
