Old 10-05-2010, 16:49
Where did you get the bearings from? I'll be doing this as long as I can get all the bits together
Old 10-05-2010, 20:54
irish s12's Avatar
rhdjapan.com as far as I can remember,much cheaper than the main dealers
Old 10-05-2010, 22:59
I've looked on there but can't find any bearings sold separately??
Old 13-05-2010, 19:55
irish s12's Avatar
If you email them then they will get them for you.
I've seen them on ebay before as well.
Old 24-10-2010, 17:16
is this the diff you've got ?
http://cgi.ebay.com/ebaymotors/OBX-H...item2a0b294c41
Was it easy to install ? What about shimming it? And the last Q is I see you've used the standard shafts, were they a straight fit in this LSD?
Old 24-10-2010, 17:45
you need 2xs12 short shafts, (passenger side), then shorten 1 of them by 8mm by grinding the end and deepen the grove on it so that the snap ring fits, then the other shaft, you take the splined end off and fit the flanged end on off of an s13 shaft, then you use the pot joint out of the s13 diff into the s12 diff, which mates up to the flange on the shaft.
Old 24-10-2010, 19:11
Thanks matey, I've been looking at the original thread. I've now started looking for a diff
http://nissansilvia.co.uk/vbb/showth...highlight=diff
Old 24-10-2010, 20:22
irish s12's Avatar
Yes thats the diff I have,I measured the lash on the original diff before I took it out and then checked it was the same once I had fitted the obx 1.
It's designed for an s13 with open diff so the original shafts fit straight in.
It's a straight copy of a Quaiffe lsd.
I've read that you need to replace the belleville springs in the obx cos they are crap but I've had no problems with mine and I'm running more than 300bhp.
I like it as a road use lsd as you really won't notice it's there unless you are giving it the loud pedal.
Old 25-10-2010, 16:20
Ronin's Avatar
Ronin Ronin is offline
Silvia Driver
So are you running both original S12 shafts with this diff? Or the two short S12 shafts?
Old 25-10-2010, 21:47
I suppose that's the better option if I'm not keen on machining shafts 'n' what not, as per Shaun's post ? That sounds like too much work and too likely for something to be done wrong lol...
