Old 26-01-2013, 19:41
jonnyjapanese jonnyjapanese is offline
jonnyjapanese is an unknown quantity at this point
Default lowering springs drop out of place ??
Hi I got a set of lowering springs from Silviagod and they are fine but I didn't know they were so low that they drop out of place when jacked up / full stretch. How do I stop this happening any hints tips would be appreciated.
Old 26-01-2013, 20:40
try cable ties might work
Old 26-01-2013, 20:57
hardly safe is it a piece of plastic holding them in
Old 27-01-2013, 11:31
check straps, use plastic coated steel cable, like on multi gyms, you can get it from b and q, and some tiny u clamps, loop each end with the u clamps, then drill a small hole near the shocker and then up near where the shocker mounts up top and bolt the cable to it, den (japster) on hear has this done.
Old 27-01-2013, 16:41
Default check straps
Ok sounds good i take it you mean this for front and rears?
Old 27-01-2013, 17:07
no, for the rears, what i did before i fitted coilovers, was make 3 little z shaped tabs for each side on the front, then drilled them n bolted them to to spring cup, top of the z shape hooks over the spring and botton bolts to the cup, this stops the fronts falling out.
Old 06-07-2014, 11:44
grahamhumm grahamhumm is offline
grahamhumm is an unknown quantity at this point
has anyone got any pics for how this is done? im a little unsure what you mean by description. mine failed its mot because of this also. and i have the standard springs in?
Old 26-07-2014, 08:36
The crux of the matter is the trailing arms need to have there movement (drop) limited.
A strap of somesort is required, I've mentioned else where on here I've done similar things of other cars and used old seat belts, doubled up and burnt holes in them, super cheap and plenty strong enough.
hese could be mounted on the top shock mount to the bottom shock mount.
If you want some seat belts pop round I have a few spare kicking around!
Old 26-07-2014, 16:18
Just cut my springs and am going to do this today. I'll try take some pics.
Old 26-07-2014, 16:28
Yer please if you could take some pics. I've been to the scrap yard and I've got some bigger lower spring seat rubbers today hoping they will hold them better. Mine are not cut. I don't see how they can fail it on MOT as it's completely oem???
