Old 22-11-2006, 16:50
they are hydraulic, there isn't any adjustment. you should really get them cleaned out, there's a lot of crap gets built up inside them
Old 22-11-2006, 17:00
I thought we had mechanical lifters in the CA18ET? (would explain why they were solid )
Have you checked that none of the bolts that hold the rockers in have been pulled out of the head, it seems to be a common problem on the 8v?
EDIT - http://www.nissansilvia.co.uk/vbb/showthread.php?t=1032 Might help
Old 22-11-2006, 17:10
Yeah but this bloke has the DET
Old 22-11-2006, 17:16
I'm acctually a total moron!!! I can't seem read or write today, it about the 4th post I've shoved on a forum that's totally useless in the last 24hrs!! Sorry all
........does this make 5 BTW
Old 22-11-2006, 17:37
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
Lol yes no5 gets a double trout
Old 22-11-2006, 17:54
Engine rebuilders have a tool which squeezes them to force out the old oil. They then need cleaning and filled up with new oil prior to fitting them. The tool is like a pressure piston with a handle. They are probably full of oil ATM!
Old 22-11-2006, 22:41
mr2sc89 mr2sc89 is offline
mr2sc89 is an unknown quantity at this point
thanks for the help, that makes alot more sense! now i can get down to it and hopfuly get her back on the road by the weekend! just fitted a half cage today aswell, looks sweet! gona have me sum fun.
Old 23-11-2006, 13:01
not technically right. I've used the equipment to do it. oil is pumped into the lifter to pop the piston out then the internals are cleaned and the lifter re-assembled.
I've stripped them when they've been compressed before, most of the time it breaks or bends the internal spring, it's the wrong way to do it.
