you can bolt the s13 TB onto the s12 manifold tho, as its a bit bigger, you will need to take the manifold off and file it out a bit tho to make it match
cheers 4 that can't really see where it's been welded but will show him and see wot he says! do the wiring plugs match up to the s13 ones coz haven't got the loom? its out of a g reg 200
Crazy little exhaust manifold on that last picture Martin. cowboy but interesting
Ok I now have a DET plenum and an ET plenum here side by side.
Where the hell would I cut them IF i did go this route?!
