Old 30-12-2006, 01:03
ahhh only other thing youve wired in recently was the after market boost guage. Could that of affected it?
Old 30-12-2006, 01:05
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
Cant see it mate as it directly replaced the one that was there before which was the exact same boost gauge which i wired into the dimmer switch.
Old 30-12-2006, 01:08
maybe its basil faulty Its 2 fast and furious for you
Old 30-12-2006, 01:21
adzs12's Avatar
Forum Regular
Anyone else got any ideas??
Old 30-12-2006, 08:03
have you had the dash out???
when i had mine out a short time ago, i think the electrics for the illumination are from a wire that goes into the back of a bulb, that plugs in the back of the dash to power the rest, im sure that bulb that carries the power is the one that illuminates the oil press and temp gauges, you may just have a bad connection there.
Old 30-12-2006, 10:25
adzs12's Avatar
Forum Regular
Yes ive had the clocks out and i know the bulb with the single black wire running to it that youve mentioned so il check on that bulb and wiring too it
Old 30-12-2006, 13:29
adzs12's Avatar
Forum Regular
That black wire that has the bulb on it that plugs into the back of the clocks, the other end goes to that little black thing by the ignition barrel??
If so ive changed that particualr bulb and still no difference
