Old 30-01-2007, 10:39
Was it a 10 figure part no. they gave you?
Old 30-01-2007, 10:43
i gave them the chassis number off of the fj20 and the mk2 of mine.they saw both parts on the micro fish and both part numbers where the same.
Old 30-01-2007, 10:45
Pretty lucky then, the bracket and the mount itself are completely different its weird
Old 30-01-2007, 10:58
yeah i know what you mean, i've just looked in the manual, the the engine mount brackets on the block are different, but i have those, and the mounts are different,they are just square blocks of rubber, with threaded bar each side, so i can just use ford ones, i have got some solid ones as well, but the cross member is the same, so its fine.
Old 13-02-2007, 20:25
come on lads, i know there's 2 of you on hear with fj20's, i only need 1 measurement from you.
