It probably just needs a relay installed. Check what voltage you are getting at the pump. Old wiring has a fair bit of resistance and you may be getting a voltage drop
![]() Quote:
Worth also considering whether the fuel lines are connected the correct way.
Checking fault codes, Fitting Relays this is a little in depth without a little "How To Guide" LOL.
checking the codes sounds a good place to start how do I do this? Then fitting a relay if it solves the problem, Which relay??? and how do I go about doing that?????? Sorry for sounding so thick, this turbo stuff is all new to me and I am determined to crack it with your help guys. |
Do you have a Walbro on yours Pukka, would I be right in saying if it needs a relay just cut the wires to the pump and install it?
Would it have to be a relay that ups the volts???????? Dont really know much about relays
