dont trust it, the standard one usually is fubar. Try a mechanical one to be sure
what oil and oil filter are you using?
![]() Quote:
10/40 semi synthetic oil with fram filter
I'm Jon's slave! He owns my arse ![]() |
mine went about half way then dropped back to 1/3 before rebuild, now it goes 3/4 cold and just under 1/2 when really hot. Think it was just general wear in crank shells and leaking turbo seals but never made any knocking noises.
I would think that a 10w-50 oil would be better at maintaining hot oil pressure than 10w-40 ![]() |
yeah but 10/40 is cheaper and she leaks from the turbo return, and turbo seals r a bit on the shite side
