No idea if it's pressurised, will find out on wednesday.
Is there a cover plate on non AC'd S12's that I can put on if I take the condensor off, or can it just be removed and left? Sorry for all the questions!
I think the pipes still poke out the firewall an inch or 2 after you've undone the pipes. Could be wrong though, was years ago when I did it.
That won't be a problem they are well out of the way, I can soon plug them.
I'll might have a bit more time on it at the weekend, after I've fitted my new brakes, and springs and filled the front struts with oil all my bits came today woohoo!
when i took mine out i took the whole lot, inc everything behind the dash as well, it didnt take too much longer
I'll strip it back to the bulkhead tonight as the rads got to come out, but I also want to get my new discs and pads fitted if possible.
Sorting the suspension out on saturday and see if any bushes need replacement, if i have any time left after that I look into dragging the rest out
Stripped it off at the weekend as I couldn't get my front struts off as the blow torch had run out of gas
Bottom fins on the rad have rotted out due to massive amounts of crap held between the AC rad and the radiator. |
them bottom bolts on the struts are cnuts for sheering off without heat, mine has has the a/c taken off before i got it, they do stick out just over an inch, i never thought, i had the dash out the other month to fit the pedal box, i should of taken the rest of the a/c out then
