I ordered an alternator 3 weeks ago, they rang me back later on and said it was being shipped over from Denmark. After countless visits it turned up today!!! WOOHOO!!!!
Totally different alternator though, some mip mop had but a different alternator in the right box and thats the only one they had! To say I'm p ssed off is an understatement!Comparing the old one to a S13 200sx one to see if it will fit, anyone else tried this???? Cheers, Dave AKA Happy Bunny
I might have an alternator to fit, do you know the Part number? |
if the pulley is the same the s13 ca18det one will fit
you can change the pulleys over but you need a decent impact gun as there fitted with bloody good locktight
Can't see why an S13 one wouldn't fit
I've got
Single grooved pulley(used) Dual grooved pulley (used) Double "V" pulley (new) Sorry, I don't which cars they're from. I think the double V will be the one. ??? |
I think pics are required to show the diff's between the last 2
Why
It's simple The first pulleys are wider and have some grooves across them The second are V-shaped. Will get pics on Friday ![]() Part numbers for grooved pulley alternators are 23100-35f10 23100-D4410 The new one is Unipart GXE2403 - 258 769 (if it helps) Last edited by zxocmars; 28-11-2007 at 21:11. |
Mk1 S12 is single vee, mk2 S12 is multi vee23100-35f10 is S13 23100-D4410 is B12,N13,T12,T72
Mines a mk2 and part number is:-
23100 12C11 but they struggled to find it with this A2T02394B is the mitsubishi number and order it off that, all checks out in there book. it's 12v 70A and a 2 pin plug.With the 200sx one I'm pretty sure it's multi vee like mine but just concerned that it might not line the belts up and kepp throwing them off, taking the power steering with it. I've brought the old alternator in to work today on the bus and will get a lift up to the 'Electrical Specialist' after work and to top it off the misses wants to go late night shopping tonight
