have a mk1 silvia i have just fitted T25 turbo from 200sx with 200sx downpipe i was wondering which one of these 2 downpipes would be better. i will be etting a 3 inch stainless system made for it prob with only 1 rear box no silencers
please tell me in you opinion item 1 or item 2 i hope item 1 coz the screamer pipe will prob sound good. is 3 inch too big for a s12 i will prob be upgrading to T28 ball bearing turbo soon thanks guys. im sure this will fit turbo as it's a 5 bolt flange and T25 is same downpipe housing as a T28 found on the SR20DET item 1/ http://cgi.ebay.co.uk/NISSAN-200SX-S...QQcmdZViewItem item 2/ http://cgi.ebay.co.uk/S13-S14-S15-Tu...QQcmdZViewItem Last edited by kylepiggy; 21-01-2008 at 19:31. |
i used 3 inch onto the t34.
i would just use a standard elbow.
![]() Quote:
surely being bigger bore would help plus the screamer would prob sound quite cool. do you think i could use a 3 inch 200sx frontpipe what they sell on fleebay cant see why it wouldn't fit and then maybe run side exit ??
where in sussex are you pukkasilvia would like to see your 120 someday
my mate had a scremmer fitted to his mr2 and it sounded rubbish, i have a stainless one fitted to mine and it goes well with my stainless manifold and full stainlees system
only reasons i say to go with the std one is because ebay stainless parts are sometimes made of very thin stainless and they tend to crack alot either side of the welds. There not allways a problem, but unless you know someone else that has bought the exact same one and has had no problems whatsoever you should bare in mind it may cause your reliability to suffer. Also the std downpipe will flow enough gasses for any t25 or t28 turbo exhaust housing so you could save yourself a few pennies for another mod
![]() Quote:
standard s12 elbow gets my vote
Same hear plus I doubt you would ever need a better one on an ET engine. Maybe if you upgraded to a DET with a T88
the standard s12 elbow is bigger internally (and a better shape) than the s13 elbow, and there's no cutting of the gearbox needed
