Old 14-02-2006, 21:18
Originally Posted by gripo
wheres mine shaun? is it that thing in the side of the plenum?
yep.
Old 17-02-2006, 11:39
mines in the plenum too.
Old 17-02-2006, 11:49
Don't think i can be bothered to put it in the plenum
Where do you lot have the map sensor tapped into? Have you teed it off of the vacuum line to the pressure reg of a specific take off from the plenum?
Old 17-02-2006, 13:10
mines off the std tapped hole (has a blanking screw in from the factory in scims) that faces passenger wing.
I have drilled and tapped the plenum about an 1.5" above that hole for teh air temp sensor so its in direct airflow from the TB. My thinking was (and im probably wrong...) that it would be in the airflow that was most likely to be an accurate representation of the actual temperature.
Old 17-02-2006, 13:22
Yeah my thoughts as well for the air temp hence the intercooler pipe location.
I could put it in the back of the inlet manifold as there is a removable plate easy to tap but it cant be a very good representation of the real temperature
