Old 12-11-2008, 12:21
what sort of price am i looking at for s13 hubs and front coilovers ? then i suppose i have to get new wheels, could i change the rears to 5 stud ? i think i'd be looking at z31 rear arms.
Old 12-11-2008, 12:25
I'd say £30 for the hubs. A complete set of coilovers will be about £250-300. There should be many available because a few people have been upgrading to the new Driftwork coilovers.
My mate is going to do 5 stud on his S12. He already has the Z31 rear. He's just slow as arseholes as actually doing anything. Of course you'd just use s14 hubs instead on the front.
A simple engine change has taken 2.5 years so far.
Old 12-11-2008, 12:29
are the s14 front hubs a straight fit like the s13 front hubs then ? so i'd just get the s14 hubs and coilovers ! what about track rod ends s13 or 14 ? cheers.
Old 12-11-2008, 12:36
You're best to check on SXOC what the S13 people do to fit the S14 hub. Something comes to mind about having to use the S14 ball joint on the lower arm.
Old 12-11-2008, 15:11
probley best i just use the s13 set up then, if i can use the s12 lower arms then it will be less messing around.
Old 12-11-2008, 18:01
Hey I'm glad these questions were put-up as it's just what I needed to know.
So is the reae fairly straight forward with Z31 parts ? WHat have you guys been using ?
Old 19-11-2008, 18:41
anyhow mart, hows your project going, any updates ?
