Old 08-12-2008, 10:54
wacomuk's Avatar
wacomuk wacomuk is offline
broken injector nozzle. this happened to me
Old 08-12-2008, 11:32
over the years ive had dodgy distrib/distrib cap and poor earth to coil. cranked fine and injectors primed fine, but weak/no/intermittent spark so smelt and looked like overfulleing when was actually undersparking lol
Old 13-12-2008, 21:33
Stephanie S12 Stephanie S12 is offline
Stephanie S12 is an unknown quantity at this point
HI,
We have checked for feed at injectors and found both terminals to be constantly live and not pulsing.....what gives them the signal to fire ?
Stephanie
Old 13-12-2008, 21:40
Draconis's Avatar
Draconis Draconis is offline
The ECU is what sends the signal out. Beyond that, I am sure these chaps would know better. I dont get how only a couple will be firing constantly while others wont when you trace the wiring back and they all feed off the same couple of wires from the ECU from my knowledge.
Old 14-12-2008, 07:59
i think they have an ignition live, and pulse the earth, im sure i read that on here somewhere.
**EDIT** according to the manual, thay have a permanent live, and the earth is pulsed, not ignition live. (but still the same in the end )
Old 15-12-2008, 04:00
Originally Posted by Stephanie S12 View Post
HI,
Stephanie
that's a knackered ECU I recon
Old 15-12-2008, 09:43
Actually thats normal to see voltage at both terminals, as they're paired parallel, thats why there's 2 earth wires. If you unplug all the other injectors you will only see one terminal with voltage on each plug.
