Old 06-02-2009, 16:44
right chaps i've checked the temp sensor & i had a broken wire& the coldstartd problom is still there, i've checked the resistances & all seems ok, the air regulaters i have are showing 60.4 ohms & opens & closes off the car at differing temps!
is it an ecu problom, when i can get it to start it does'nt fast idle (cold start) it just sits at 500rpm & wavers up to 750rpm then back down again?
i've checked & double checked everythink i think, i've even ceaned up all my earths, the ecu has some dodgy wiring repairs so thats my next place to check but other than that i dont know what to do
i've also got two good temp sensors, & 2 air regulators, a spare FICD & i've cleaned them up, i have a feeling a wire orsome wire have possibly broken/chafed or the ecu is faulty
does the ecu come up on the self diagnose's if it has a fault????
Old 06-02-2009, 17:31
look here for fault codes and how to check them.
http://www.nissansilvia.co.uk/vbb/showthread.php?t=156
