Rob, That's going REALLY too lean from about 4.5k. Is that not detting? get the boost turned down or you're going to melt a piston
yeas thats very lean, it won't last long at all, thats probley ok for tickover matey
Yeah 14.2 is dangerously lean, the operator shouldn't have even taken it up that far. Leanest you want is 13:1 and even that is a bit borderline.
Don't top speed it, it will wreck a piston.
is that an ET or 16v ?
If your on a budget you could always wack a cheap 5th injector setup on it. In your case it might actually do the trick. Demon tweeks to adjustable pressure switches which would make it more manageable
