has it dragged shite up from the tank with drifting it ? then blocked the injectors.take your filter off and empty it onto a white piece of paper and see if theres lots of crap.
There was some dirt in the filter but il put in a new one just to be safe.
But i got it running again by blocking of the return fuel line. Its always under high preasure so i think the fpr is broken, il install a adjustable fpr this week.
87 silvia (ca18det) 94 Alfa Romeo 155 2.0 8v ts (daily driver)(planning Lancia Delta swap) 84 silvia (ca18et oldtimer) Turbolag is nothing but foreplay |
Put a multimeter on the injectors and see if you have a pulse and check you have a spark.
How can you feel bubbles in a fuel line?
it runs fine now, I just picked the car up couple weeks ago but was standing still for many years. Most of the time it runs really good , only got 60k on the clock.but the previous owner disasembled a lot of stuf that i had to putt back.
So I had some trouble with things missing and loose (like the distributor came of on the way home) But it seemed i dave pulled a vacium in my fuel line but my fuel pressure regulator seems to be always on open and under high pressure so im gonna instal an aftermarket adjustable one so i can boost it up a bit safely.
