That's weird when used on an s13 hub the BMW disc is too large a centre bore. You could use one of the BMW holes but it will need to be ovaled a bit to match the pcd. The other 3 will need drilling
i've got r32 calipers now and found out they sit further away than the s14 calipers, so in theory i could use gtr 295mm discs with a 11.5 mm spacer like doski has used, only for some reason r32 discs are extortionate price at £150 each
, i'd like to use bigger discs but i could live with 295mm instead of 274mm std ones, i'am not going to be trackin the car only straight lining, so they should be adequate until next year, then i will probably do what you have done mart.cheers for the help.
i though s14 are 5 holes and not 4 ?
yes, but you get them re drilled to 4 stud mate.
i used skyline r32 discs in the end.
Current I got R33 GTST dics and calipers here. I think this will fit too?!
