Old 04-10-2009, 20:03
That's weird when used on an s13 hub the BMW disc is too large a centre bore. You could use one of the BMW holes but it will need to be ovaled a bit to match the pcd. The other 3 will need drilling
Old 06-10-2009, 20:12
i've got r32 calipers now and found out they sit further away than the s14 calipers, so in theory i could use gtr 295mm discs with a 11.5 mm spacer like doski has used, only for some reason r32 discs are extortionate price at £150 each, i'd like to use bigger discs but i could live with 295mm instead of 274mm std ones, i'am not going to be trackin the car only straight lining, so they should be adequate until next year, then i will probably do what you have done mart.cheers for the help.
Old 03-10-2014, 08:36
JDM_ArTo JDM_ArTo is offline
JDM_ArTo is an unknown quantity at this point
i though s14 are 5 holes and not 4 ?
Old 03-10-2014, 10:01
yes, but you get them re drilled to 4 stud mate.
Old 03-10-2014, 10:03
i used skyline r32 discs in the end.
Old 03-10-2014, 10:48
Current I got R33 GTST dics and calipers here. I think this will fit too?!
Old 04-12-2014, 21:42
steves12zx steves12zx is offline
steves12zx is an unknown quantity at this point
Can't you use the standard front discs with the s14 calipers?!
