Old 22-02-2010, 00:49
Raas_s12 Raas_s12 is offline
Raas_s12 is an unknown quantity at this point
Default engine wont start
hi every one....... i am new to this and i wanna get things right i have been told that i can get help here well here goes
i bought a s12 1989 shape and it was misfiring........it has mods such as t28 turbo front mount intercooler a fifth injector
now when i bought it the engine would misfire very badly and me like a geniuse drove it for 117 miles
the car then died out and would not start i have changed the battery new plugs new ht leads and still nothing
i need help big time to get my car started any ideas........?
Old 22-02-2010, 01:11
irish s12's Avatar
Has it got sparks?
Old 22-02-2010, 10:51
yes i have also changed the spark plugs.......i am a bit lost now.
Old 22-02-2010, 11:20
do a compression check as the 5th injector might have burnt out the valves as usually they are more hassle then they are worth.
Old 22-02-2010, 11:46
ok will do is there any thing else i can do jus to have a list of things because the car is in manchester and im in leicester and i will be going there very soon to do the work.
Old 22-02-2010, 12:09
the 5th injectors are usually on a pressure switch, se nissan used a metro oil pressure switch that came on far to early, 5psi if i remember correctly, this would probably bore wash.
