Old 20-05-2010, 15:34
londonsilvia londonsilvia is offline
londonsilvia is an unknown quantity at this point
not gap... the width of the spark plug to unscrew it with a socket.
Old 20-05-2010, 16:05
Dr Silvia's Avatar
they're the slim type if that helps
Old 20-05-2010, 18:50
10mm... just checked.
Old 20-05-2010, 22:32
It's worth noting that with 10mm being quoted for a spark plug tool that's the size of the thread, not the size of the actual hex itself (16mm I think)
Old 20-05-2010, 22:40
laymans terms... please...
Old 20-05-2010, 22:43
Well the hole that the spark plug screws in to is 10mm wide.
The socket that fits on the plug is 16mm.
But for some reason spark plug tools refer to the 10mm which may mislead you.
As long as you buy something recognised as a 10mm spark plug tool you'll be fine, but if you were using a normal deep socket you'd use a 16mm.
Old 20-05-2010, 22:59
is this what you mean? 10mm/16mm? i got this but i cant get to the last 2 spark plugs, i need a bendy one... http://www.halfords.com/webapp/wcs/s...egoryId_165469
this is the bendy one im going to try, will it be long enough?
http://www.halfords.com/webapp/wcs/s...Id_165469#dtab
cheers for helping me understand.
