well i have another fuel rail here from another engine but ive also got a guage coming tonight to test the pressure.
Would i put the guage between the pump and rail or after the old regulator.?? |
Probably just before. Are you sure that One or more of your injectors are partially stuck open? Ie bore wash. Fuel reg is the likely condidate but could also be a knackered afm
Would it run rough with a knackered afm??
Possible boost leak around crossover pipe ends as it does stall when pulling up to a junction with brakes on |
Yeh it would but rough. Is there any codes on the ECU?
ok cool well i pulled the plug off afm and it stalled.
wound in the screw on the afm a bit no real change. I have not pulled codes yet was going to look tomorrow i think. not sure whether it will give me codes properly as the loom has been cut and shut. ill try anyway. I have pulled a plug and its very black/sooty and i have connected a pressure guage to the fuel and it shows just over 2 bar so thats ok. Would a water temp sensor cause this also and does it have a cold start injector?? |
Temp sensor is a common-ish fault of DET rich running, and can be tested with the info in the WSM,
It has a cold start valve located under the throttle body. |
