i've just bought this...
http://www.ebay.co.uk/itm/3004140497...84.m1439.l2649 (saab 9000 cooler) ...which has the same 2" pipe work fittings. i plan to use a combo of new pipes from ebay, some of the existing s13 sidemount currently on mine and some of this to make life easier... http://www.ebay.co.uk/itm/Black-Sili...item27bbce2497 (flexible silicone hose, rated to 180+ degrees, 13.5 bar)
1989 Mk2 Red Auto 1988 Mk2 Blue Manual 1988 Mk2 Red Auto (Ex-Silviagod) 1988 Mk2 Blue Manual (Donor) Last edited by nedge2k; 10-07-2013 at 11:30. |
put a proper bar and plate intercooler in there, with cast end tanks, mines cheap enough and would'nt take much fitting
Im running the T2 still. Will upgrade later on but ok for now. S13eater how much piping/bends etc are with your intercooler? I considered yours previously but was a little unsure
![]() Also Nedge that flexible hose looks like the business but can you cut it to length without risk of leaks? |
No idea yet but would imagine so. There's some other stuff on fleabay too that looks a bit more conventional but it doesn't give a pressure rating
1989 Mk2 Red Auto 1988 Mk2 Blue Manual 1988 Mk2 Red Auto (Ex-Silviagod) 1988 Mk2 Blue Manual (Donor) |
theres a company called ash silicone hoses that is cheaper than samco and a lot cheaper, i use them.
