Old 15-08-2013, 19:22
tss240zg tss240zg is offline
I dont think the clutches the same - there are more bolts on the FJ20 one holding it on than the CA18. Unless of course 2.0 litre one is off a CA20
Old 15-08-2013, 19:24
FJ20 has a much larger clutch
I know this as I have both engines
Old 16-08-2013, 19:40
Austin666 Austin666 is offline
Austin666 is an unknown quantity at this point
cheers people , i think i will buy a new one the box looks like its been sat in a damp garage for years.
p.s that manifold nut is a right bugger to get at , got to change the turbo as this one is seized
Old 16-08-2013, 20:58
nedge2k nedge2k is offline
Administrator
i've found chopping a cheap spanner in half with an angle grinder does the trick nicely. the biggest pain is getting the water feed pipes away from the back of the head without bending them - you can try taking them off the turbo in situ but it's easier to disconnect them from the inlet side of the head.
1985 Mk1 Black Auto
1989 Mk2 Red Auto
1988 Mk2 Blue Manual
1988 Mk2 Blue Manual (Donor)
