This is by far the easiest way to do it and takes 5mins.
1)Take sidelight out 2/3 screws depends on little or big sidelights,this allows you to pull the grill out a bit if needed. 2)4 screws that hold the black plastic surround on around the light unit,give it a wiggle about to get it off as it wedges under lid at top(it can catch on grill or sidelight as well)See no1 3)4 bolt screws that hold the top lid on. You can now get to the bulb holder at the back of light
If the black side cover catches on the lid why dont you take the lid off first
cos the lid bolts are under it
lol at least someone is thorough round here
To see if its a bulb check if they work on sidelight. The sidelights work by running the bulbs in series as opposed to parallel to get the reduced voltage.
Therefore if they don't work at all on sidelight then its defo a bulb.
