Old 31-07-2006, 22:14
try a search on www.club-s12.org/forums as loads of the US boys have done it with a safc-II
Old 01-08-2006, 15:39
wacomuk's Avatar
wacomuk wacomuk is offline
s13 injectors can be made to fit the standard rail. you can force the rubber connectors over the top of the injector (crude but it can be done)
its best to have a custom rail made
the s13 rail wont fit a Silvia (s13 have equal runners silvias don't)
if you have some way of controlling the injectors its prob best to use a adjustable fuel reg
you only need to add more fuel above 1bar of boost
Old 02-08-2006, 07:38
turbozx turbozx is offline
Cheers got a safc 2 now and all the bit like injectors, both fuel rails, so ill look at whats involved, cant be too hard! the safc looks pretty easy to wire in. what type of fuel pressure reg do i need?
Old 02-08-2006, 15:45
wacomuk's Avatar
iv used FSE fuel regs with out problems
Old 02-08-2006, 16:23
I had to bin my FSE reg. It wouldn't maintain stable base pressure.
So you'd be driving along, have a boot and then it would remain on high pressure.
Old 02-08-2006, 16:33
datdrift's Avatar
datdrift datdrift is offline
ive got a 2nd hand fse reg on mine, and it seems to have given me a missfire once or twice, in low revs, on anything more than light throttle? also sometimes it makes the idle unsteady? so think i might bin/ebay it....
Old 02-08-2006, 20:05
so what reg would you advise i get?
