right have a slight issue with my s12, was playing with a calibra, pissed all over him and then had lack of power and big cloud of smoke behind me, cam belt isnt snapped or skipped teeth, runs but sound like only on 2 cylinders. im thinkin piston rings but not certain, any advise would be apreciated
Did you top speed it?
Sounds like a holed piston to me. Remove the oil cap and see if it spits lots of oil out due to the excessive crank case pressure |
i was doing about 140 when it happened, smoke comes out the oil filler cap, white smoke
Sounds about right.
What spark plugs are you running? |
the colder ngk ones bcpr78es or sumthing liek that
Hmm, using them should stop the problem unless there is something wrong with the timing or fueling.
This is the expected damage: ![]() I would do a compression test to tell. I suspect you've got damage to number 3. |
the timing has been retarded from what i was told to 15deg btdc. i am running 11 psi tho
Well 15 degs is standard.
Are you running an intercooler? |
grim sorry to hear that
s12s dont like doing 135+ with the standard fuel pump and increased boost. i suspect you have holed a piston or at the least blown the head gasket. chuck a 50 quid replacement engine in her.Put a wanted ad up
