Old 29-12-2005, 21:15
any idea with th fj or rb25 box in.
Old 29-12-2005, 23:11
i have had 145 in most of my et powered s12s running approx 225bhp or more.(this is with 17" wheels so bear in mind with the speed reading)
I blew a hole in a piston of my t3 blowered s12 when i took it to 140 then started slowing down. I believe the std Fuel pump could not supply enough fuel.
My det is going well. i get around 75mph in second gear as the rpm limiter is at 7k .once the limiter is increased i should see 80-85.This should be a more accurate reading as i have 15" wheels now
When i spoke to Den at trax last year (det s12) he said he had gone into the 170mph+ area that day (private road obviously )
Old 29-12-2005, 23:17
Shaun, get me the ratios and I'll do a calc for ya.
Old 29-12-2005, 23:59
kennyboy's Avatar
kennyboy kennyboy is offline
Default top speed
hello peebs,
Shawn is correct i did kick some skyline arse that day, allan could only manage 133 on the 1.25 mile stretch and i did 137.9( with a fooked motor aswell) and i rubbed his nose in it by holding my ticket infront of him as he was talking to one of his skyline buddies
I reckon shawn , the power you'll have out of the beast will pull the limiter in fifth.
I have seen the the end of the 150 mph on my private test track of coarse,
have a speedo shot somewhere will scan it , that will make everybody smile.
With the correct conditions, i reckon its possible.
Old 30-12-2005, 20:07
i will do martin,yep ken i'am wanting some gearing that will take me over 200mph , maybe there's a gear kit for the rb25 box
Old 31-12-2005, 16:41
kennyboy's Avatar
Default rb25 box
My pal alex has just got his gts skyline at lastand it is running an rb25 mototr in that so i will see what i can find out for ya mate ,
have a good one for tonight aswell lookfoward to speak to yu next year .
Old 31-12-2005, 17:29
yep av a good un ken,something has cropped up so i don't know weather i'am going to break the s12 or not, if so what would the engine be worth without maniflds, you all must know the spec by now, its got to be worth 1200 quid, piper cam, 400 quid i payed for the head porting, je forged pistons, mig wired block, 200sx rods and squirt jets, billet ajustable vernier, lightened and ballanced flywheel,obviousley injectors, billet fuel rail, inlet plenum, top mount exhaust manifold, turbo, wastegate would be sold seperate, oh and theres the omex, 3 inch full stainless exhaust proper stainless as well, filter, ally rad, costom intercooler and fully rebuilt subframe with lsd and full poly bushes and new bearings,brand new kyb's and uprated springs, bonnet, good wings and doors, full bodykit if someone can get it off, i need to raise about 3k
