Old 08-12-2006, 20:02
Beany-s12's Avatar
Default s13 inlet
i was speaking to someone today who said the s13 inlet manifold will fit on the s12 quite easilly! is he right coz i've got one and it would save all the trouble of swapping injectors and throtle body!
Old 08-12-2006, 20:07
nope.
Easy if your good at Aluminium welding and have a fair bit of time.as you need to weld the s12's inlet runners and flange to the det plenum.
Old 08-12-2006, 20:08
Originally Posted by s13eater
nope.
Much easier answer
Old 08-12-2006, 21:15
Beany-s12's Avatar
well i've gotta spare s12 manifold and an s13 one so if any1 could send me a pic off one thats been done i'll ask my mate how much it'll cost to weld it all up!
Old 11-12-2006, 11:13
Mine:
Some other one I found on Goodle years ago:
Old 11-12-2006, 13:49
you can bolt the s13 TB onto the s12 manifold tho, as its a bit bigger, you will need to take the manifold off and file it out a bit tho to make it match
Old 11-12-2006, 20:56
Beany-s12's Avatar
cheers 4 that can't really see where it's been welded but will show him and see wot he says! do the wiring plugs match up to the s13 ones coz haven't got the loom? its out of a g reg 200
Old 11-12-2006, 22:57
Crazy little exhaust manifold on that last picture Martin. cowboy but interesting
Old 16-12-2006, 19:05
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
Ok I now have a DET plenum and an ET plenum here side by side.
Where the hell would I cut them IF i did go this route?!
