Old 30-12-2006, 01:27
Default Dash lights
Im having an issue with the back lights on my clocks, i have illumination on the oil pressure gauge and water temp gauge but nothing on the speedo, rev clock, fuel gauge and std boost gauge, any ideas?
Ive been chopping old bits of loom out from the std ecu coz i now have the omex but the lights are all on the ignition side of things aint they?
Old 30-12-2006, 01:45
Originally Posted by adzs12
Im having an issue with the back lights on my clocks ,ive been chopping old bits of loom out
lmao only messing. Yes your rite,it shouldnt effect things on the car loom. Do your headlights work and is the dashlight dimmer module still plugged in properly at the back and have power to it
Old 30-12-2006, 01:50
Yes mate i have head lights and all other lights on the instrument panels, just literally no speedo light, rev light, fuel and std boost gauge. The dimmer is plugged in and working as i can dim the fuel light and water temp
Old 30-12-2006, 02:03
ahhh only other thing youve wired in recently was the after market boost guage. Could that of affected it?
Old 30-12-2006, 02:05
Cant see it mate as it directly replaced the one that was there before which was the exact same boost gauge which i wired into the dimmer switch.
Old 30-12-2006, 02:08
maybe its basil faulty Its 2 fast and furious for you
Old 30-12-2006, 02:21
Anyone else got any ideas??
Old 30-12-2006, 09:03
have you had the dash out???
when i had mine out a short time ago, i think the electrics for the illumination are from a wire that goes into the back of a bulb, that plugs in the back of the dash to power the rest, im sure that bulb that carries the power is the one that illuminates the oil press and temp gauges, you may just have a bad connection there.
Old 30-12-2006, 11:25
Yes ive had the clocks out and i know the bulb with the single black wire running to it that youve mentioned so il check on that bulb and wiring too it
Old 30-12-2006, 14:29
That black wire that has the bulb on it that plugs into the back of the clocks, the other end goes to that little black thing by the ignition barrel??
If so ive changed that particualr bulb and still no difference
