Old 18-03-2007, 11:20
s12Rob's Avatar
s12Rob s12Rob is offline
Default battery relocation
has anyone done this, how easy is it gunna be, is it just a case of welding the bracket for the battery in the boot and running 4 guage cabe down the car?
Old 18-03-2007, 11:29
You can buy battery boxes. Try to use a battery that doesn't breath.
Run the wire to the starter motor terminal, and keep the original wiring to it. Then remove the battery terminals off that part of wiring.
