Go Back   S12OC UK Forum > Main Categories > Ice
Old 31-03-2007, 12:52
James H's Avatar
James H James H is offline
Default A few custom audio installs..
Thought you might like to see a few little jobs i have done in my Silvia,
Parcel shelf
CD Surround
also half way thru my sub & amp set up which will be in soon just waiting on the acoustic carpet to arrive, willpost a more pics soon. Let me know what you think?
Old 31-03-2007, 20:03
well the rear parcel shelf incorporating where the original speakers went is pretty tidy They look like infinity speakers? I think i have the same ones. Im not a fan of 6x9 speakers but there a good all-rounder if your trying to keep costs to a reasonable level
Old 31-03-2007, 22:30
bigtim's Avatar
bigtim bigtim is offline
i like that design as well
Old 01-04-2007, 11:54
James H's Avatar
Cheers guys, yer going for the simple tidy look. The 6x9's are JBL ones & like you say a nice all rounder, got a couple of amps & a Audiobahn sub going in but once again nothing too special as I am keeping cost's done as would rather spend mnoey else where. Hope to have the ammp & sub set up done by Wednesday.
Old 07-04-2007, 19:46
James H's Avatar
A couple of pics of the subwoofer & amp unit i made for the silvia, made it so it would fit in between the arches & designed so stuff can be chucked in the boot without damaging the amps or wires.
Old 11-05-2007, 19:59
irish s12's Avatar
setup looks tidy but the amps need air space for cooling.i have my amp screwed onto the back of the seat,with a quick release so that i can remove the sub if i need to use the boot.i will be upgrading my sound system soon to a custom made system as that is what i do for a living.i've only got one of the door builds built so far so i will post some pictures once i have finnished.
Old 16-05-2007, 16:38
James H's Avatar
Cheers mate, yer i know what you mean but don't worry not that you can see it too well but the amp & lid have a gap to allowing breathing also there not running alot anyway so doesn't get all that hot.
Old 17-05-2007, 23:50
last year after jae my amplifier cooked in my boot as it got hot under the gazebo..........
Looks tidy, Audiobahn are a nice choice, Is that a 10" sub?
Old 18-05-2007, 15:55
James H's Avatar
Nope a little 8" sub, like i said nothing big but as you said Auidobahn are pretty good so delivers well for its size.
Old 07-06-2007, 16:19
.. and the duvets, pillows and everything else we hurled in prior to our trip home it took quite alot for that amp to protect itself..
there appears to be sufficient room for breathing there, as long as the air can travel along the fins it will perform as desired, very neat too!
one word of warning though, maybe get a grille for that sub, i've had some worrying moments where i've nearly pierced mine (thank god for aluminium cones!)
