Old 28-11-2007, 18:20
Angry Would you believe it???
I ordered an alternator 3 weeks ago, they rang me back later on and said it was being shipped over from Denmark. After countless visits it turned up today!!! WOOHOO!!!!
Totally different alternator though, some mip mop had but a different alternator in the right box and thats the only one they had!
To say I'm p ssed off is an understatement!
Comparing the old one to a S13 200sx one to see if it will fit, anyone else tried this????
Cheers,
Dave AKA Happy Bunny
Old 28-11-2007, 18:46
zxocmars zxocmars is offline
Cheers,
Dave,
I might have an alternator to fit, do you know the Part number?
Old 28-11-2007, 19:00
if the pulley is the same the s13 ca18det one will fit
Old 28-11-2007, 19:02
you can change the pulleys over but you need a decent impact gun as there fitted with bloody good locktight
Old 28-11-2007, 20:18
Can't see why an S13 one wouldn't fit
Old 28-11-2007, 20:37
I've got
Single grooved pulley(used)
Dual grooved pulley (used)
Double "V" pulley (new)
Sorry, I don't which cars they're from. I think the double V will be the one. ???
Old 28-11-2007, 20:54
I think pics are required to show the diff's between the last 2
Old 28-11-2007, 22:02
Why
It's simple
The first pulleys are wider and have some grooves across them
The second are V-shaped.
Will get pics on Friday
Part numbers for grooved pulley alternators are
23100-35f10
23100-D4410
The new one is Unipart GXE2403 - 258 769 (if it helps)
Old 29-11-2007, 00:40
Originally Posted by zxocmars View Post
Why
It's simple
23100-35f10
23100-D4410
You said one was dual grooved Mk1 S12 is single vee, mk2 S12 is multi vee
23100-35f10 is S13
23100-D4410 is B12,N13,T12,T72
Old 29-11-2007, 07:48
Mines a mk2 and part number is:-
23100 12C11 but they struggled to find it with this
A2T02394B is the mitsubishi number and order it off that, all checks out in there book.
it's 12v 70A and a 2 pin plug.
With the 200sx one I'm pretty sure it's multi vee like mine but just concerned that it might not line the belts up and kepp throwing them off, taking the power steering with it.
I've brought the old alternator in to work today on the bus and will get a lift up to the 'Electrical Specialist' after work and to top it off the misses wants to go late night shopping tonight
