Old 22-12-2007, 15:02
Default Can't set the dizzy
Hi,
I remove the distributor and now i can't start.
According to me the crankshaft must be at 0 (-5, 0 red mark, +5, +10, +15, +20.
There are 3 holes and the crank of the distributor:2 are similars and 1 different.
According the fsm the different one must be turn counterclockwise of one tooth of gear about the mark on distributor.
Perhaps, i set it correctly but can't starter is there any relay or fuse for ignition?
P.S: all find before my rebuilding because i blew my head gasket.
Cheers.
Old 22-12-2007, 15:33
You need to set the crankshaft to TDC (0) with number 1 cylinder on its compression stroke (both valves are shut).
Then you need to use the dot on the shaft. Its a dot... not a hole, chances are you are using one of the holes a split pin goes through
Old 23-12-2007, 01:20
I'll test the dot one one tooth counterclock wise.
Is there any scan on ignition turbo model? Because i only have the non turbo one.
Is there any relay or fuse to for distributor?
Thanks
