Old 13-02-2006, 21:29
rob turbo's Avatar
Default Need LSD
im needing to get one in mine as the standard unit in not up to the job i expect from a rear wheeler'...
im sure the s13 one do's the trick & fits streight on, however i needs to know which year diff & what the deal is with the driveshafts needed, do mine fit...?? a full top to bottom please guys..
hhelllllllllllllllllllllllp......
Old 13-02-2006, 21:31
ask 30PSI hes got an s13 one on his motor, hes also done the how to for it if im right.
Old 13-02-2006, 21:49
toney200sx on the sxoc had on for sale last week for 50 quid, he's at rotherham, you will need to put the inners of the slip diff onto your crown wheel and use the s12 diff case, then you need 2 passengers side shafts, one of the shafts you take 8mm off of the end with a grinder, then deepen the groove to take the split ring, the other shaft has the end taken off and the s13 drive shaft end put on.
Old 13-02-2006, 21:53
Shaun your starting to sound like magpie martin
Old 13-02-2006, 22:06
oh no
Old 13-02-2006, 22:23
Who will make LSD for s12 will be rich for sure.
Even the one who make a s12 VLSD kit, driveshafts customized + s13vlsd.
Old 21-03-2006, 23:58
rob turbo's Avatar
still could do with one, i havent been on for a few weeks as tiscali have been dicking my broadband around..
noticed there was one for sale with all the parts needed to bolt strieght on.. driveshafts etc...
dos any one have another or can knock a set up one & gimmie a price
cheers
